Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Object Upload (SDK for Node.js)/ Uploading an Object - Browser-Based (SDK for Node.js)
Updated on 2025-02-07 GMT+08:00
Function
Performing a browser-based upload is to upload objects to a specified bucket in HTML form. The maximum size of an object is 5 GB.
You can call ObsClient.createPostSignatureSync to generate request parameters for a browser-based upload. You can use Node.js code to simulate a browser-based upload. For details, see post-object-sample. You can also perform a browser-based upload with the following steps:
  1. Call ObsClient.createPostSignatureSync to generate request parameters for authentication.
  2. Prepare an HTML form page.
  3. Enter the request parameters in the HTML page.
  4. Select a local file and upload it in browser-based mode.
Method
ObsClient.createPostSignatureSync(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Key
string
Yes
Explanation:
Object name An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
Expires
Number
No
Explanation:
Validity period of authentication for a browser-based upload
Restrictions:
None
Value range:
A positive integer, in seconds
Default value:
300
FormParams
Object
No
Explanation:
Parameters used for browser-based uploads, excluding key, policy, and signature.
Restrictions:
None
Value range:
  • acl
  • cache-control
  • content-type
  • content-disposition
  • content-encoding
  • expires
Default value:
None
Responses
Table 2 Responses
Parameter
Type
Description
OriginPolicy
String
Explanation:
policy not encoded using Base64. This parameter can only be used for verification.
Policy
String
Explanation:
policy in the form.
Signature
String
Explanation:
signature in the form.
Code Examples
The following sample code shows how to generate the parameters in a browser-based upload request.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
function createSignedUrlSync() {
  const params = {
    // Specify the bucket name.
    Bucket: "examplebucket",
    // Specify an object (example/objectname in this example).
    Key: "example/objectname",
    // Specify the validity period of the signed URL, in seconds (3600 in this example).
    Expires: 3600,
    // Specify the headers that must be carried in the request.
    FormParams: {
      'x-obs-acl': 'public-read',
      'content-type': 'text/plain'
  // Create a signed URL for uploading an object.
  const res = obsClient.createPostSignatureSync(params);
  console.log("OriginPolicy : %s", res.OriginPolicy);
  console.log("Policy: %s", res.Policy);
  console.log("Signature: %v", res.Signature);
Code of an HTML form example is as follows:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<form action="http://bucketname.your-endpoint/" method="post" enctype="multipart/form-data">
Object key
<!-- Object name -->
<input type="text" name="key" value="objectname" />
<p>
ACL
<!-- Object ACL -->
<input type="text" name="x-obs-acl" value="public-read" />
<p>
Content-Type
<!-- Object MIME type -->
<input type="text" name="content-type" value="text/plain" />
<p>
<!-- Base64 code of the policy -->
<input type="hidden" name="policy" value="*** Provide your policy ***" />
<!-- AK -->
<input type="hidden" name="AccessKeyId" value="*** Provide your access key ***"/>
<!-- Signature information -->
<input type="hidden" name="signature" value="*** Provide your signature ***"/>
<input name="file" type="file" />
<input name="submit" value="Upload" type="submit" />
</form>
</body>
</html>
You can directly download the HTML form example PostDemo.
