Configuring Static Website Hosting for a Bucket (SDK for Python)
Function
You can host static website resources such as HTML web pages, flash files, or audio and video files in an OBS bucket, so that you can provide these hosted resources using the bucket's website endpoint to end users. Typical use cases include:
- Redirecting all requests to another website
- Redirecting specific requests
This API configures static website hosting for a bucket.
Restrictions
- Periods (.) should be avoided in the target bucket name, or there may be certificate verification failures on the client when you use HTTPS for access.
- The request body of the website configuration cannot exceed 10 KB.
- To configure static website hosting for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketWebsite in IAM or PutBucketWebsite in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.setBucketWebsite(bucketName, website, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
website |
Yes |
Explanation: Input parameters for configuring static website hosting. For details, see Table 1. Default value: None |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Header (SDK for Python). Default value: None |
Parameter |
Type |
Description |
redirectAllRequestTo |
No if used as a request parameter |
Explanation: Redirection rules for all requests. For details, see Table 2. Default value: None |
indexDocument |
Explanation: Default page configuration. For details, see Table 3. Default value: None |
errorDocument |
Explanation: Error page configuration. For details, see Table 4. Default value: None |
routingRules |
list of RoutingRule |
Explanation: List of routing rules. For details, see Table 5. Default value: None |
- errorDocument, indexDocument, and routingRules must be used together and they cannot be used with redirectAllRequestsTo.
- When errorDocument, indexDocument, and routingRules are used together, routingRules can be left blank.
- You must specify either the combo of fields ErrorDocument, IndexDocument, and RoutingRules, or the RedirectAllRequestsTo field.
Parameter |
Type |
Description |
hostName |
str |
Yes if used as a request parameter |
Explanation: Host name used for redirection, for example, www.example.com Restrictions: The host name must comply with the host name rules. Default value: None |
protocol |
str |
Explanation: Protocol used for redirection Value range:
Parameter |
Type |
Description |
suffix |
str |
Explanation: Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket. Value range: This parameter can neither be left blank nor contain slashes (/). Default value: None |
Parameter |
Type |
Description |
key |
str |
Explanation: Object name to use when a 4XX error occurs. This parameter specifies the webpage to display when an error occurs. Value range: The value must contain 1 to 1,024 characters. Default value: None |
Parameter |
Type |
Description |
condition |
Explanation: Conditions that must be met for the specified redirect to apply Value range: See Table 6. Default value: None |
redirect |
Explanation: Details about the redirection. For details, see Table 7. Default value: None |
Parameter |
Type |
Description |
keyPrefixEquals |
str |
Explanation: Object name prefix for the redirection to take effect. If the name prefix of the requested object is the same as the value specified for this parameter, the redirection rule takes effect. For example, to redirect the requests for the object ExamplePage.html, set KeyPrefixEquals to ExamplePage.html. Restrictions: This parameter cannot be used together with httpErrorCodeReturnedEquals. Value range: The value must contain 1 to 1,024 characters. Default value: None |
httpErrorCodeReturnedEquals |
int |
Explanation: HTTP error code for the redirection to take effect. If there is an error, and the error code returned is the same as the value specified for this parameter, the redirection rule takes effect. For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set httpErrorCodeReturnedEquals to 404 in Condition, and set ReplaceKeyWith to NotFound.html in Redirect. Restrictions: This parameter cannot be used together with keyPrefixEquals. Value range: See Error Codes. Default value: None |
Parameter |
Type |
Description |
protocol |
str |
hostName |
str |
Explanation: Host name used for redirection Default value: None |
replaceKeyPrefixWith |
str |
Explanation: Object name prefix used in the redirection request Value range: The value must contain 1 to 1,024 characters. Default value: None |
replaceKeyWith |
str |
Explanation: Object name used in the redirection request Restrictions: This parameter cannot be used together with replaceKeyPrefixWith. Value range: The value must contain 1 to 1,024 characters. Default value: None |
httpRedirectCode |
int |
Explanation: HTTP status code in the response to the redirect request. For details, see Status Code. Default value: None |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
Code Examples
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 |
from obs import ObsClient from obs import WebsiteConfiguration from obs import IndexDocument from obs import ErrorDocument from obs import RoutingRule from obs import Condition from obs import Redirect import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Specify an error page when a 4XX error occurs. errorDocument = ErrorDocument(key='error.html') # Specify a default page. indexDocument = IndexDocument(suffix='index.html') # Specify a rule for redirecting requests to NotFound.html if the status code is 404. routingRule1 = RoutingRule(condition=Condition(httpErrorCodeReturnedEquals=404), redirect=Redirect(protocol='http', replaceKeyWith='NotFound.html')) # Configure the redirection rules in list format. Multiple rules can be configured. routingRules = [routingRule1] bucketName = "examplebucket" # Configure static website hosting for the bucket. resp = obsClient.setBucketWebsite(bucketName, WebsiteConfiguration(errorDocument=errorDocument, indexDocument=indexDocument, routingRules=routingRules)) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Set Bucket Website Succeeded') print('requestId:', resp.requestId) else: print('Set Bucket Website Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Set Bucket Website Failed') print(traceback.format_exc()) |
Feedback
Was this page helpful?
Chatbot
