Multipart Upload Overview (SDK for Python)
You can upload large files using multipart upload. Multipart upload is applicable to many scenarios, including:
- Files to be uploaded are larger than 100 MB.
- The network condition is poor. Connection to the OBS server is constantly down.
- Sizes of files to be uploaded are uncertain.
A multipart upload consists of the following steps:
- Initiate a multipart upload (ObsClient.initiateMultipartUpload).
- Upload parts one by one or concurrently (ObsClient.uploadPart).
- Assemble parts (ObsClient.completeMultipartUpload) or abort the multipart upload (ObsClient.abortMultipartUpload).
This example shows a complete multipart upload, including initiating a multipart upload, uploading parts, and assembling parts.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 |
# -*- coding:utf-8 -*- from obs import ObsClient,CompleteMultipartUploadRequest, CompletePart import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: #Bucket name bucketName = "examplebucket" #Object name objectKey = "objectname" # Specify the MIME type for the object. contentType = 'text/plain' # Initiate a multipart upload. resp = obsClient.initiateMultipartUpload(bucketName, objectKey, contentType=contentType) #Obtain the uploadId. uploadId = resp.body["uploadId"] #Specify the size of the part to upload. partSize = 512 * 1024 * 1024 #Specify the part number. partNum = 1 # Specify whether object indicates the file path. True is used here. The default value is False. isFile = True #Specify the local object file to upload. filepath = r"D:\tmp\file.txt" contentLength = os.path.getsize(filepath) #Start offset of a part in the source file. offset = 0 etags = {} while offset < contentLength: partSize = min(partSize, (contentLength - offset)); # Upload parts. resp1 = obsClient.uploadPart(bucketName, objectKey, partNum, uploadId, filepath, isFile, partSize, offset) etags[partNum] = resp1.body.etag offset = offset + partSize partNum = partNum + 1 completes = [] for i in range(1, partNum): completes.append(CompletePart(i, etags[i])) # Assemble parts. completeMultipartUploadRequest = CompleteMultipartUploadRequest(parts = completes) resp = obsClient.completeMultipartUpload(bucketName, objectKey, uploadId, completeMultipartUploadRequest) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Upload Part Succeeded') print('requestId:', resp.requestId) print('etag:', resp.body.etag) else: print('Upload Part Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('multPartsUpload Failed') print(traceback.format_exc()) |
Below lists other multipart upload operations:
Feedback
Was this page helpful?
Chatbot
