Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Static Website Hosting (SDK for Node.js)/ Configuring Static Website Hosting (SDK for Node.js)
Updated on 2025-02-07 GMT+08:00
Function
You can host static website resources such as HTML web pages, flash files, or audio and video files in an OBS bucket, so that you can provide these hosted resources using the bucket's website endpoint to end users. Typical use cases include:
  • Redirecting all requests to another website
  • Redirecting specific requests
This API configures static website hosting for a bucket.
Restrictions
  • Periods (.) should be avoided in the target bucket name, or there may be certificate verification failures on the client when using HTTPS for access.
  • The request body of the website configuration cannot exceed 10 KB.
  • To configure static website hosting for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketWebsite in IAM or PutBucketWebsite in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
Method
ObsClient.setBucketWebsite(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
RedirectAllRequestsTo
RedirectAllRequestTo
No
Explanation:
Redirection rule for all requests
Restrictions:
None
Value range:
See Table 2.
Default value:
None
IndexDocument
IndexDocument
No
Explanation:
Default page configuration.
Restrictions:
None
Value range:
See Table 3.
Default value:
None
ErrorDocument
ErrorDocument
No
Explanation:
Error page configuration.
Restrictions:
None
Value range:
See Table 4.
Default value:
None
RoutingRules
RoutingRule[]
No
Explanation:
Redirection rule list
Restrictions:
None
Value range:
See Table 5.
Default value:
None
  • ErrorDocument, IndexDocument, and RoutingRules must be used together and must not be used with RedirectAllRequestsTo.
  • When ErrorDocument, IndexDocument, and RoutingRules are used together, RoutingRules can be left blank.
  • You must set either these three parameters (ErrorDocument, IndexDocument, and RoutingRules) or RedirectAllRequestsTo.
Table 2 RedirectAllRequestsTo
Parameter
Type
Mandatory (Yes/No)
Description
HostName
string
Yes if RedirectAllRequestsTo is specified
Explanation:
Domain name used for redirection, for example, www.example.com
Restrictions:
The domain name must comply with the domain name standards.
Value range:
None
Default value:
None
Protocol
string
No
Explanation:
Protocol used for redirection
Restrictions:
None
Value range:
http or https
Default value:
None
Table 3 IndexDocument
Parameter
Type
Mandatory (Yes/No)
Description
Suffix
string
Yes if IndexDocument is specified
Explanation:
Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket.
Restrictions:
This parameter can neither be left blank nor contain slashes (/).
Value range:
None
Default value:
None
Table 4 ErrorDocument
Parameter
Type
Mandatory (Yes/No)
Description
Key
string
No if ErrorDocument is specified
Explanation:
The object name that is used when a 4XX error occurs. This element specifies the page that is returned when an error occurs.
Restrictions:
None
Value range:
The key can contain 1 to 1,024 characters.
Default value:
None
Table 5 RoutingRule
Parameter
Type
Mandatory (Yes/No)
Description
Condition
Condition
No
Explanation:
Conditions that must be met for the specified rule to take effect
Restrictions:
None
Value range:
See Table 6.
Default value:
None
Redirect
Redirect
Yes if RoutingRule is specified
Explanation:
Details about the redirection
Restrictions:
None
Value range:
See Table 7.
Default value:
None
Table 6 Condition
Parameter
Type
Mandatory (Yes/No)
Description
KeyPrefixEquals
string
No
Explanation:
Object name prefix for the redirection to take effect. If the name prefix of the requested object is the same as the value specified for this parameter, the redirection rule takes effect.
For example, to redirect the requests for the object ExamplePage.html, set KeyPrefixEquals to ExamplePage.html.
Restrictions:
This parameter cannot be used together with HttpErrorCodeReturnedEquals.
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
string
No
Explanation:
HTTP error code for the redirection to take effect. If an error code returned is the same as the value specified for this parameter, the redirection rule takes effect.
For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set HttpErrorCodeReturnedEquals to 404 in Condition and set ReplaceKeyWith to NotFound.html in Redirect.
Restrictions:
This parameter cannot be used together with KeyPrefixEquals.
Value range:
See Error Codes.
Default value:
None
Table 7 Redirect
Parameter
Type
Mandatory (Yes/No)
Description
Protocol
string
No if used as a request parameter
Explanation:
Restrictions:
None
Value range:
http or https
Default value:
None
HostName
string
Explanation:
Restrictions:
Value range:
None
Default value:
None
ReplaceKeyPrefixWith
string
Explanation:
Object name prefix used in the redirection request
Restrictions:
None
Value range:
Default value:
None
ReplaceKeyWith
string
Explanation:
Object name used in the redirection request
Restrictions:
This parameter cannot be used together with replaceKeyPrefixWith.
Value range:
Default value:
None
HttpRedirectCode
string
Explanation:
HTTP status code in the response to the redirection request
Restrictions:
None
Value range:
See Status Codes.
Default value:
None
Responses
Table 8 Responses
Type
Description
Table 9
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results.
For details, see Table 9.
Table 9 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 10.
InterfaceResult
Table 11
Explanation:
Results outputted for a successful call. For details, see Table 11.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 10 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 11 BaseResponseOutput
Parameter
Type
Description
RequestId
string
Explanation:
Code Examples
This example configures website hosting for bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function setBucketWebsite() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify a default page (index.html in this example).
      IndexDocument: { Suffix: 'index.html' },
      // Specify an error page (error.html in this example).
      ErrorDocument: { Key: 'error.html' },
      // Configure redirection for all requests.
      RedirectAllRequestsTo : {HostName : 'www.example.com', Protocol : 'http'}
      // Specify redirect rules for requests.
      RoutingRules: [
        { Redirect: { HostName: "www.a.com", Protocol: obs.ProtocolHttp, ReplaceKeyPrefixWith: "prefix", HttpRedirectCode: "304" } },
        { Redirect: { HostName: "www.b.com", Protocol: obs.ProtocolHttps, ReplaceKeyWith: "replaceKey", HttpRedirectCode: "304" } },
    // Configure the website settings for the bucket.
    const result = await obsClient.setBucketWebsite(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Set bucket(%s)'s website configuration successful!", params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
setBucketWebsite();
