Help Center/ Object Storage Service/ SDK Reference/ Python/ Other APIs (SDK for Python)/ Generating Authentication Parameters for Browser-Based Uploads (SDK for Python)
Updated on 2024-11-26 GMT+08:00
Function
This API generates parameters for authentication. The parameters can be used to perform a browser-based upload through POST operations.
There are two request parameters generated for authentication:
  • policy, which corresponds to the policy parameter in the form.
  • signature, which corresponds to the signature parameter in the form.
Restrictions
Method
ObsClient.createPostSignature(bucketName, objectKey, expires, formParams)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
No
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
objectKey
str
No
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
expires
int
No
Explanation:
Expiration time of authentication for a browser-based upload
Value range:
An integer greater than or equal to 0, in seconds
Default value:
300
formParams
dict
No
Explanation:
Parameters of browser-based uploads, not including key, policy, and signature.
Value range:
  • acl
  • cache-control
  • content-type
  • content-disposition
  • content-encoding
  • expires
Default value:
None
Responses
Table 2 List of returned results
Parameter
Type
Description
originPolicy
str
Explanation:
policy not encoded by Base64. This parameter can only be used for verification.
Example: {"expiration":"2023-09-12T12:52:59Z","conditions":[{"content-type":"text/plain"},{"bucket":"examplebucket"},{"key":"example/objectname"},]}"
Default value:
None
policy
str
Explanation:
Base64-encoded value of policy in the form
Example: eyJleHBpcmF0aW9uIjoiMjAyMy0wOS0xMlQxMjo1Mjo1OVoiLCJjb25kaXRpb25zIjpbeyJjb250ZW50LXR5cGUiOiJ0ZXh0L3BsYWluIn0seyJidWNrZXQiOiJleGFtcGxlYnVja2V0In0seyJrZXkiOiJleGFtcGxlL29iamVjdG5hbWUifSxdfQ==
Default value:
None
signature
str
Explanation:
signature in the form
Example: g0jQr4v9VWd1Q2FOFDG6LGfV9Cw=
Default value:
None
Code Examples
This example generates authentication parameters policy and signature for a browser-based upload.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName = "examplebucket"
    objectKey = "objectname"
    # Configure the validity period (in seconds) for a browser-based upload request. 3600 is used as an example.
    expires = 3600
    # Specify parameters for a browser-based upload except key, policy, and signature. In this example, x-obs-acl is set to private and content-type is set to text/plain.
    formParams = {'x-obs-acl': 'private', 'content-type': 'text/plain'}
    # Create parameters for a browser-based upload.
    resp = obsClient.createPostSignature(bucketName, objectKey, expires, formParams)
    print('originPolicy:', resp.originPolicy)
    print('policy:', resp.policy)
    print('signature:', resp.signature)
except:
    print(traceback.format_exc())
