Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Configuring Logging for a Bucket (SDK for Go)
Updated on 2024-12-09 GMT+08:00
Function
This API enables logging for a bucket (source) and configures another bucket (target) to store the log files. When a bucket is created, logging is not enabled by default. You can call this API to enable logging for the bucket. With logging enabled, a log message is generated for each operation on the bucket. Multiple log messages are packed into a file. The bucket for storing log files must be specified when logging is enabled. It can be the bucket logging is enabled for, or any other bucket you have access to. If you specify another bucket for storing logs, the bucket must be in the same region as the logged bucket. You can also configure access to log files and the name prefix of log files.
Restrictions
  • OBS creates log files and uploads them to the bucket. Before enabling logging for a bucket, you need to create an IAM agency to delegate OBS to upload log files to the specified bucket.
  • To configure logging for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketLogging in IAM or PutBucketLogging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) SetBucketLoggingConfiguration(input *SetBucketLoggingConfigurationInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
Yes
Explanation:
Input parameters for configuring bucket logging. For details, see Table 2.
Table 2 SetBucketLoggingConfigurationInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Agency
string
Yes if the parameter is in a request to enable bucket logging
Explanation:
Name of the IAM agency created by the owner of the target bucket for OBS.
You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency.
Restrictions:
By default, the IAM agency only requires the PutObject permission to upload logs to the target bucket. If default encryption is enabled for the target bucket, the agency also requires the KMS Administrator permission in the region where the target bucket is located.
Default value:
None
TargetBucket
string
Yes if you enable logging for the bucket
Do not set this parameter when you disable logging for the bucket.
Explanation:
Name of the bucket for storing log files
Restrictions:
  • This bucket must be in the same region as the bucket with logging enabled.
  • A bucket name:
Default value:
None
TargetPrefix
string
Explanation:
Name prefix for log files stored in the log storage bucket
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
TargetGrants
[]Grant
No
Explanation:
Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 3.
Table 3 Grant
Parameter
Type
Mandatory (Yes/No)
Description
Grantee
Grantee
Yes if used as a request parameter
Explanation:
Grantee information. For details, see Table 4.
Permission
PermissionType
Explanation:
Granted permission
Value range:
See Table 7.
Default value:
None
Table 4 Grantee
Parameter
Type
Mandatory (Yes/No)
Description
Type
GranteeType
Yes
Explanation:
Grantee type
Value range:
See Table 5.
Default value:
None
ID
string
Yes if Type is set to GranteeUser
Explanation:
Account (domain) ID of the grantee
Value range:
To obtain an account ID, see Obtaining the Account ID.
Default value:
None
DisplayName
string
No
Explanation:
Account name of the grantee
Restrictions:
  • Starts with a letter. Contains 6 to 32 characters.
  • Contains only letters, digits, hyphens (-), or underscores (_).
Default value:
None
URI
GroupUriType
Yes if Type is set to GranteeGroup
Explanation:
Authorized user group
Value range:
See Table 6.
Default value:
None
Table 5 GranteeType
Constant
Default Value
Description
GranteeGroup
Group
User group
GranteeUser
CanonicalUser
Individual user
Table 6 GroupUriType
Constant
Default Value
Description
GroupAllUsers
AllUsers
All users
Table 7 PermissionType
Constant
Default Value
Description
PermissionRead
READ
Read permission
PermissionWrite
WRITE
Write permission
PermissionReadAcp
READ_ACP
Permission to read ACL configurations
PermissionWriteAcp
WRITE_ACP
Permission to modify ACL configurations
PermissionFullControl
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
Responses
Table 8 List of returned results
Parameter
Type
Description
output
*BaseModel
Explanation:
Returned results. For details, see Table 9.
err
error
Explanation:
Error messages returned by the API
Table 9 BaseModel
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Code Examples
This example configures logging for bucket examplebucket, with obs_test_agency as the agency, TargetPrefixtest/ as the prefix for generated log files, and TargetBucketname as the bucket for storing log files.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSignature(obs.SignatureObs)/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetBucketLoggingConfigurationInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify an agency name (obs_test_agency as an example).
    input.Agency = "obs_test_agency"
    // Specify a bucket (TargetBucketname as an example) for storing generated log files.
    input.TargetBucket = "TargetBucketname"
    // Specify a prefix (TargetPrefixtest/ as an example) for log files to be generated.
    input.TargetPrefix = "TargetPrefixtest/"
    // Configure logging for the bucket.
    output, err := obsClient.SetBucketLoggingConfiguration(input)
    if err == nil {
        fmt.Printf("Set bucket(%s)'s logging configuration successful!\n", input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Set bucket(%s)'s logging configuration fail!\n", input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
