Updated on 2025-04-02 GMT+08:00
Overview
Table 1 lists the mathematical functions supported by DLI.
Table 1 Mathematical functions
Function
Syntax
Value Type
Description
abs
abs(DOUBLE a)
DOUBLE or INT
Returns the absolute value.
acos
acos(DOUBLE a)
DOUBLE
Returns the arc cosine value of a.
asin
asin(DOUBLE a)
DOUBLE
Returns the arc sine value of a.
atan
atan(DOUBLE a)
DOUBLE
Returns the arc tangent value of a.
bin
bin(BIGINT a)
STRING
Returns a number in binary format.
bround
bround(DOUBLE a)
DOUBLE
In HALF_EVEN rounding, the digit 5 is rounded up if the digit before 5 is an odd number and rounded down if the digit before 5 is an even number. For example, bround(7.5) = 8.0, bround(6.5) = 6.0.
bround
bround(DOUBLE a, INT d)
DOUBLE
The value is rounded off to d decimal places in HALF_EVEN mode. The digit 5 is rounded up if the digit before 5 is an odd number and rounded down if the digit before 5 is an even number. For example, bround(8.25, 1) = 8.2, bround(8.35, 1) = 8.4.
cbrt
cbrt(DOUBLE a)
DOUBLE
Returns the cube root of a.
ceil
ceil(DOUBLE a)
DECIMAL
Returns the smallest integer that is greater than or equal to a. For example, ceil(21.2) = 22.
conv
conv(BIGINT num, INT from_base, INT to_base), conv(STRING num, INT from_base, INT to_base)
STRING
Converts a number from from_base to to_base. For example, convert 5 from decimal to quaternary using conv(5,10,4) = 11.
cos
cos(DOUBLE a)
DOUBLE
Returns the cosine value of a.
cot1
cot1(DOUBLE a)
DOUBLE or DECIMAL
Returns the cotangent of a specified radian value.
degress
degrees(DOUBLE a)
DOUBLE
Returns the angle corresponding to the radian.
e
e()
DOUBLE
Returns the value of e.
exp
exp(DOUBLE a)
DOUBLE
Returns the value of e raised to the power of a.
factorial
factorial(INT a)
BIGINT
Returns the factorial of a.
floor
floor(DOUBLE a)
BIGINT
Returns the largest integer that is less than or equal to A. For example, floor(21.2) = 21.
greatest
greatest(T v1, T v2, ...)
DOUBLE
Returns the greatest value of a list of values.
hex
hex(BIGINT a) hex(STRING a)
STRING
Converts an integer or character into its hexadecimal representation.
least
least(T v1, T v2, ...)
DOUBLE
Returns the least value of a list of values.
ln
ln(DOUBLE a)
DOUBLE
Returns the natural logarithm of a given value.
log
log(DOUBLE base, DOUBLE a)
DOUBLE
Returns the natural logarithm of a given base and exponent.
log10
log10(DOUBLE a)
DOUBLE
Returns the base-10 logarithm of a given value.
log2
log2(DOUBLE a)
DOUBLE
Returns the base-2 logarithm of a given value.
median
median(colname)
DOUBLE or DECIMAL
Returns the median.
negative
negative(INT a)
DECIMAL or INT
Returns the opposite number of a. For example, if negative(2) is given, –2 is returned.
percentile
percentile(colname,DOUBLE p)
DOUBLE or ARRAY
Returns the exact percentile, which is applicable to a small amount of data. Sorts a specified column in ascending order, and then obtains the exact pth percentage. The value of p must be between 0 and 1.
percentile_approx
percentile_approx (colname,DOUBLE p)
DOUBLE or ARRAY
Returns the approximate percentile, which is applicable to a large amount of data. Sorts a specified column in ascending order, and then obtains the value corresponding to the pth percentile.
pi
pi()
DOUBLE
Returns the value of pi.
pmod
pmod(INT a, INT b)
DECIMAL or INT
Returns the positive value of the remainder after division of x by y.
positive
positive(INT a)
DECIMAL, DOUBLE, or INT
Returns the value of a, for example, positive(2) = 2.
pow
pow(DOUBLE a, DOUBLE p), power(DOUBLE a, DOUBLE p)
DOUBLE
Returns the value of a raised to the power of p.
radians
radians(DOUBLE a)
DOUBLE
Returns the radian corresponding to the angle.
rand
rand(INT seed)
DOUBLE
Returns an evenly distributed random number that is greater than or equal to 0 and less than 1. If the seed is specified, a stable random number sequence is displayed.
round
round(DOUBLE a)
DOUBLE
Round off
round
DOUBLE
Rounds a to d decimal places, for example, round(21.263,2) = 21.26.
shiftleft
shiftleft(BIGINT a, INT b)
INT
Bitwise signed left shift. Interprets a as a binary number and shifts the binary number b positions to the left.
shiftright
shiftright(BIGINT a, INT b)
INT
Bitwise signed right shift. Interprets a as a binary number and shifts the binary number b positions to the right.
shiftrightunsigned
shiftrightunsigned(BIGINT a, INT b)
INT
Bitwise unsigned right shift. Interprets a as a binary number and shifts the binary number b positions to the right.
sign
sign(DOUBLE a)
DOUBLE
Returns the sign of a. 1.0 is returned if a is positive. –1.0 is returned if a is negative. Otherwise, 0.0 is returned.
sin
sin(DOUBLE a)
DOUBLE
Returns the sine value of the given angle a.
sqrt
sqrt(DOUBLE a)
DOUBLE
Returns the square root of a.
tan
tan(DOUBLE a)
DOUBLE
Returns the tangent value of the given angle a.
