Updated on 2025-09-11 GMT+08:00
Creating an Application
Scenarios
If your organization is complex and you need to divide resources by organization for centralized and refined management, you can create applications to logically classify components. After an application is created, you can add sub-applications and new components to the application, making service module management clear and intuitive.
Constraints and Limitations
  • If the large-scale application structure is selected, you can configure sub-applications.
  • Only one type of node (sub-application/component) is allowed at the same level under an application or sub-application.
  • A maximum of 50 components and 50 groups can be configured for an application.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications.
  4. Click Create Application.
  5. On the application creation page, you can create an application based on your service scenario.
    COC provides two creation modes: advanced creation and quick creation.
If the resource structure is complex, for example, an application has multiple components, and each component involves resources in multiple regions, you can use the advanced creation method.
  1. On the application creation page, click the Advanced Creation tab.
  2. Select an application structure type based on the complexity of the application structure.
    • Lightweight: Lightweight applications feature fewer layers and a simpler structure. Application layer structure: Applications > Components > Groups > Resources
    • Large-scale: Large-scale applications have complex structures. Application layer structure: Applications > Sub-applications (multi-layer) > Components > Groups > Resources.
  3. Set the application structure by referring to Table 1.
    After setting all mandatory fields of the current level, click OK to go to the next level. After all mandatory fields of all levels are specified, click OK to complete application creation.
    Table 1 Parameters for creating an application
    Parameter
    Description
    Example Value
    Application
    Customize an application name based on the naming rule.
    The application name can contain 3 to 50 characters, including letters, digits, hyphens (-), and underscores (_).
    Test_application
    Description
    (Optional) Description of the application.
    Subapplication Name
    This parameter is required only when the large-scale application type is selected.
    Customize the sub-application name based on the naming rule.
    The sub-application name can contain 3 to 50 characters, including letters, digits, hyphens (-), and underscores (_).
    Test_Sub-application
    Description
    (Optional) Description of a sub-application.
    Component
    Customize the component name based on the naming rule.
    The component name can contain 3 to 60 characters, including letters, digits, hyphens (-), and underscores (_).
    Test-component
    Group
    Customize a group name based on the naming rule.
    The group name can contain 3 to 60 characters, including letters, digits, hyphens (-), and underscores (_).
    Test-group
    Available Cloud Service Providers
    Select the cloud service provider to which the target instance belongs.
    Huawei Cloud
    Resource Association Method
    Select a resource association mode.
    • Manual association: You can manually associate resources with the group you created for unified management.
    • Automatic association: You can add all resources with the same tag in an enterprise project to a resource group.
    Manual association
    Region
    Select a region from the drop-down list.
    Enterprise Project
    This parameter is required only when Resource Association Method is set to Automatic association.
    Select an enterprise project from the drop-down list.
    Tag Key
    Enter the tag key of the target instance.
    testKey
    Tag Value
    (Optional) Enter the tag value of the target instance.
    testValue
    Associate Resource with APM Environment
    (Optional) Configure the application, component, and environment of the APM service corresponding to the group. APM service performance information can be obtained through this field during fault diagnosis.
  4. Click Create to complete application creation.
If the resource structure is simple, for example, an application requires only Huawei Cloud resources and the resources need to be associated with only one group, you can use the quick creation function.
  1. On the application creation page, click the Quick Creation tab.
  2. Set basic application information.
    Figure 1 Basic information
    Table 2 Basic information parameters
    Parameter
    Description
    Example Value
    Application
    The name can contain 3 to 50 characters, including letters, digits, hyphens (-), and underscores (_).
    Test_application
    Application Description
    (Optional) Description of the application scenario.
    The default value is Huawei Cloud and cannot be changed.
    Huawei Cloud
    Region
    CN North-Beijing4
  3. Add resources by referring to Table 3.
    Table 3 Parameters for adding a resource
    Parameter
    Description
    Example Value
    • Manual association: Click Select Resource to manually associate the resource data with the group for management.
    Enterprise Project
    default
    Tag Key
    testKey
    Tag Value
    testValue
  4. Click OK.
    The system automatically generates components and groups named {Application-name}-component and {Application name}-group, respectively.
Creating a Sub-application
You can create sub-applications under an application only when you select the Large-scale application structure type during application creation.
  1. Log in to COC.
  4. In the navigation pane on the left, select the application for which you want to create a sub-application for and click .
  5. Set parameters for creating a sub-application.
    Table 4 Parameters for creating a sub-application
    Parameter
    Description
    Example Value
    Subapplication Name
    Description
  6. Click OK.
