Help Center/
Cloud Operations Center/
User Guide/
Faults/
Incident Management/
Rejecting an Incident Ticket
Updated on 2025-09-17 GMT+08:00
Scenarios
After an incident ticket is created, the incident handler can reject it if it is unreasonable or due to other reasons. If rejected, the incident creator can either modify and submit the incident ticket or close it.
- Log in to COC.
- In the navigation pane, choose Fault Management > Incidents.
- On the Pending tab page, select the target incident ticket and click its title.
- Click Reject in the upper right corner.
Figure 1 Rejecting an incident ticket
- Enter the rejection reason and click OK.
Figure 2 Entering the reason for rejecting the incident ticket
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
