Updated on 2025-09-08 GMT+08:00
Searching for Resources by Tag
After tags are added to resources, you can search for resources by tag using either of the following methods.
Searching for ECSs by Tag
On the Elastic Cloud Server page, search for ECSs by tag key or key-value pair.
  1. Log in to the management console.
  2. Click in the upper left corner and select a region and project.
  3. Click . Under Compute, click Elastic Cloud Server.
  4. In the search box, select a tag key under Resource Tag and then a tag value, and press Enter.
    You can search for ECSs by multiple tags and they are automatically joined with AND.
    Figure 1 Searching by tag
    Figure 2 Searching by tag
Filtering Resources on the TMS Console
  2. In the upper right corner of the page, click the username and select Tag Management from the drop-down list.
  3. On the Resource Tags page, set the search criteria, including Region, Resource Type, and Resource Tag.
  4. Click Search.
    All the resources that meet the search criteria will be displayed in the Search Result area.
