Updated on 2025-09-17 GMT+08:00
Handling Alarms
Scenarios
After an aggregated alarm is generated, you can quickly handle it on COC and apply the response solution using jobs or scripts.
Precautions
Only the owner can handle the current alarm.
Handling Alarms
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Alarms.
  3. Choose Aggregated Alarms > Unhandled Alarms.
  4. Select the alarm to be handled and choose More > Handle in the Operation column.
  5. Configure information in Task Type.
  6. Click OK.
    The alarm is handled.
