Obtaining the Static Website Hosting Configuration of a Bucket (SDK for Go)
Function
You can host static website resources such as HTML web pages, flash files, as well as audio and video files in an OBS bucket, so that you can access these hosted resources using the bucket's website endpoint. Typical use cases include:
- Redirecting all requests to another website
- Redirecting specific requests
This API returns the static website hosting configuration of the bucket.
Restrictions
- To obtain the static website hosting configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketWebsite in IAM or GetBucketWebsite in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) GetBucketWebsiteConfiguration(bucketName string) (output *GetBucketWebsiteConfigurationOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 3. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
RedirectAllRequestsTo |
Explanation: Redirection rule of all requests For details, see Table 4. |
IndexDocument |
Explanation: Default page configuration. For details, see Table 5. |
ErrorDocument |
Explanation: Error page configuration. For details, see Table 6. |
RoutingRules |
Explanation: Redirection rule list For details, see Table 7. |
Parameter |
Type |
Description |
HostName |
string |
Explanation: Host name used for redirection, for example, www.example.com Restrictions: The host name must be in the standard host name format. Default value: None |
Protocol |
Explanation: Protocol used for redirection Value range: See Table 10. Default value: None |
Parameter |
Type |
Description |
Suffix |
string |
Yes if IndexDocument is specified |
Explanation: Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket. Value range: This parameter can neither be left blank nor contain slashes (/). Default value: None |
Parameter |
Type |
Description |
Key |
string |
No if ErrorDocument is specified |
Explanation: Object name to use when a 4XX error occurs. This parameter specifies the webpage to display when an error occurs. Value range: The value must contain 1 to 1,024 characters. Default value: None |
Parameter |
Type |
Description |
Condition |
Explanation: Conditions that must be met for the specified redirect to apply Value range: See Table 8. Default value: None |
Redirect |
Explanation: Details about the redirect request. For details, see Table 9. |
Parameter |
Type |
Description |
KeyPrefixEquals |
string |
No |
Explanation: Object name prefix when the redirection is applied. When a request is sent for accessing an object, the redirection rule takes effect if the object name prefix matches the value specified for this parameter. For example, to redirect the request for object ExamplePage.html, set the KeyPrefixEquals to ExamplePage.html. Restrictions: This parameter cannot be used together with HttpErrorCodeReturnedEquals. Value range: The value must contain 1 to 1,024 characters. Default value: None |
HttpErrorCodeReturnedEquals |
string |
No |
Explanation: HTTP error codes when the redirection takes effect. The specified redirection is applied only when the error code returned equals the value specified for this parameter. For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set HttpErrorCodeReturnedEquals to 404 in Condition, and set ReplaceKeyWith to NotFound.html in Redirect. Restrictions: This parameter cannot be used together with KeyPrefixEquals. Value range: See Error Codes. Default value: None |
Parameter |
Type |
Description |
Protocol |
HostName |
string |
Explanation: Host name used for redirection Default value: None |
ReplaceKeyPrefixWith |
string |
Explanation: Object name prefix used for redirection Value range: The value must contain 1 to 1,024 characters. Default value: None |
ReplaceKeyWith |
string |
Explanation: Object name used for redirection Restrictions: This parameter cannot be used together with replaceKeyPrefixWith. Value range: The value must contain 1 to 1,024 characters. Default value: None |
HttpRedirectCode |
string |
Explanation: HTTP status code in the response to the redirect request. For details, see Status Code. Default value: None |
Constant |
Default Value |
Description |
ProtocolHttp |
http |
HTTP protocol used for redirection |
ProtocolHttps |
https |
HTTPS protocol used for the redirection request |
Code Examples
This example returns the website configuration of bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Specify a bucket name. bucketname := "examplebucket" // Obtain the website configuration of the bucket. output, err := obsClient.GetBucketWebsiteConfiguration(bucketname) if err == nil { fmt.Printf("Get bucket(%s)'s website configuration successful!\n", bucketname) fmt.Printf("Get bucket metadata successful!\n") fmt.Printf("RequestId:%s\n", output.RequestId) fmt.Printf("Suffix:%s\n", output.IndexDocument.Suffix) fmt.Printf("Key:%s\n", output.ErrorDocument.Key) for index, routingRule := range output.RoutingRules { fmt.Printf("Condition[%d]-KeyPrefixEquals:%s, HttpErrorCodeReturnedEquals:%s\n", index, routingRule.Condition.KeyPrefixEquals, routingRule.Condition.HttpErrorCodeReturnedEquals) fmt.Printf("Redirect[%d]-Protocol:%s, HostName:%s, ReplaceKeyPrefixWith:%s, HttpRedirectCode:%s\n", index, routingRule.Redirect.Protocol, routingRule.Redirect.HostName, routingRule.Redirect.ReplaceKeyPrefixWith, routingRule.Redirect.HttpRedirectCode) } return } fmt.Printf("Get bucket(%s)'s website configuration fail!\n", bucketname) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
