Server-Side Encryption (SDK for Go)
Function
This API configures server-side encryption for objects, so that they will be encrypted or decrypted when you upload them to or download them from a bucket.
The encryption and decryption happen on the server side.
There are different encryption methods for you to choose from. Available encryption methods include server-side encryption with KMS-managed keys (SSE-KMS) and server-side encryption with customer-provided keys (SSE-C). Both of the two methods use the AES-256 algorithm.
With SSE-KMS, OBS uses the keys provided by KMS for server-side encryption.
With SSE-C, OBS uses the keys and MD5 values provided by customers for server-side encryption.
When server-side encryption is used, the returned ETag value is not the object's MD5 value. OBS will verify the object's MD5 value as long as the upload request includes the Content-MD5 header, no matter whether server-side encryption is used or not.
For more information, see Server-Side Encryption.
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) PutFile(input *PutFileInput) (output *PutObjectOutput, err error)
Supported APIs
The following table lists APIs related to server-side encryption:
Method in OBS SDK for Go |
Description |
Supported Encryption Method |
ObsClient.PutObject |
Sets the encryption algorithm and key during object upload to enable server-side encryption. |
SSE-KMS SSE-C |
ObsClient.PutFile |
Sets the encryption algorithm and key during file upload to enable server-side encryption. |
SSE-KMS SSE-C |
ObsClient.GetObject |
Sets the decryption algorithm and key during object download to decrypt the object. |
SSE-C |
ObsClient.CopyObject |
SSE-KMS SSE-C |
ObsClient.GetObjectMetadata |
Sets the decryption algorithm and key when obtaining the object metadata to decrypt the object. |
SSE-C |
ObsClient.InitiateMultipartUpload |
Sets the encryption algorithm and key when initializing a multipart upload task to enable server-side encryption for the final object generated. |
SSE-KMS SSE-C |
ObsClient.UploadPart |
Sets the encryption algorithm and key during multipart upload to enable server-side encryption for parts. |
SSE-C |
ObsClient.CopyPart |
SSE-C |
Code Examples
This example encrypts object example/objectname that is uploaded using streaming.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 |
package main import ( "crypto/md5" "encoding/base64" "fmt" "os" "strings" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.PutObjectInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify the object (example/objectname as an example) to upload. input.Key = "example/objectname" // Specify the content to upload. input.Body = strings.NewReader("Hello OBS") // Specify a server-side encryption header (obs.SseCHeader as an example). key := os.Getenv("Key") digest := md5.New() digest.Write([]byte(key)) bodyHash := digest.Sum(nil) input.SseHeader = obs.SseCHeader{ Encryption: "AES256", Key: base64.StdEncoding.EncodeToString([]byte(key)), // 32byteslongsecretkeymustprovided KeyMD5: base64.StdEncoding.EncodeToString(bodyHash), } // Upload you local file using streaming. output, err := obsClient.PutObject(input) if err == nil { fmt.Printf("Put object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket) fmt.Printf("RequestId:%s\n", output.RequestId) fmt.Printf("StorageClass:%s, ETag:%s\n", output.StorageClass, output.ETag) return } fmt.Printf("Put object(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
This example downloads the encrypted object example/objectname using streaming.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 |
package main import ( "crypto/md5" "encoding/base64" "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.GetObjectInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify the object (example/objectname as an example) to download. input.Key = "example/objectname" // Specify a server-side encryption header (obs.SseCHeader as an example). key := os.Getenv("Key") digest := md5.New() digest.Write([]byte(key)) bodyHash := digest.Sum(nil) input.SseHeader = obs.SseCHeader{ Encryption: "AES256", Key: base64.StdEncoding.EncodeToString([]byte(key)), // 32byteslongsecretkeymustprovided KeyMD5: base64.StdEncoding.EncodeToString(bodyHash), } // Download the object using streaming. output, err := obsClient.GetObject(input) if err == nil { // Close output.Body after using it, to avoid connection leakage. defer output.Body.Close() fmt.Printf("Get object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket) fmt.Printf("StorageClass:%s, ETag:%s, ContentType:%s, ContentLength:%d, LastModified:%s\n", output.StorageClass, output.ETag, output.ContentType, output.ContentLength, output.LastModified) // Read the object content. p := make([]byte, 1024) var readErr error var readCount int for { readCount, readErr = output.Body.Read(p) if readCount > 0 { fmt.Printf("%s", p[:readCount]) } if readErr != nil { break } } return } fmt.Printf("List objects under the bucket(%s) fail!\n", input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
