Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Logging (SDK for Node.js)/ Configuring Logging for a Bucket (SDK for Node.js)
Updated on 2025-02-07 GMT+08:00
A bucket in the Infrequent Access or Archive storage class cannot be used as a log target bucket.
Function
This API enables logging for a bucket (source) and configures another bucket (target) to store the log files. When a bucket is created, logging is not enabled by default. You can call this API to enable logging for the bucket. With logging enabled, a log message is generated for each operation on the bucket. Multiple log messages are packed into a file. The target bucket for storing log files must be specified when logging is enabled. It can be the bucket logging is enabled for, or any other bucket you have access to. If you specify another bucket for storing logs, the bucket must be in the same region as the logged bucket. You can also specify access permissions and name prefixes for log files.
Restrictions
  • OBS creates log files and uploads them to the bucket. Before enabling logging for a bucket, you need to create an IAM agency to delegate OBS to upload log files to the specified bucket. For details about how to create an agency, see Cloud Service Delegation.
  • To configure logging for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketLogging in IAM or PutBucketLogging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
  • The source bucket and target bucket must be in the same region.
  • Before configuring bucket logging, you need to create an agency for OBS on IAM and obtain the agency name. For details, see Creating an IAM Agency.
Method
ObsClient.setBucketLogging(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Agency
string
Yes if used in a request for enabling bucket logging
Explanation:
Name of the IAM agency created by the owner of the target bucket for OBS.
Restrictions:
By default, the IAM agency only requires the PutObject permission to upload logs to the target bucket. If default encryption is enabled for the target bucket, the agency also requires the KMS Administrator permission in the region where the target bucket is located.
Value range:
You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency.
Default value:
None
LoggingEnabled
LoggingEnabled
Yes if you enable logging for the bucket
Do not set this parameter when you disable logging for the bucket.
Explanation:
Logging configuration information. If this parameter is not set, bucket logging is disabled by default.
Restrictions:
None
Value range:
See LoggingEnabled.
Default value:
None
Table 2 LoggingEnabled
Parameter
Type
Mandatory (Yes/No)
Description
TargetBucket
string
Explanation:
Name of the bucket for storing log files.
Restrictions:
  • This bucket must be in the same region as the bucket with logging enabled.
  • A bucket name:
Value range:
Default value:
None
TargetPrefix
string
Explanation:
Name prefix for log files stored in the target bucket.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
TargetGrants
Grant
No
Explanation:
Permission information list of grantees, which defines grantees and their permissions for log files.
Restrictions:
None
Value range:
See Grant.
Default value:
None
Table 3 Grant
Parameter
Type
Mandatory (Yes/No)
Description
Grantee
Grantee
Yes
Explanation:
Grantees and permissions
Restrictions:
None
Value range:
See Grantee.
Default value:
None
Permission
PermissionType
Yes
Explanation:
Granted permission
Restrictions:
None
Value range:
See PermissionType.
Default value:
None
Table 4 Grantee
Parameter
Type
Mandatory (Yes/No)
Description
Type
GranteeType
Yes if used as a request parameter
Explanation:
Grantee type
Restrictions:
None
Value range:
See Table 5.
Default value:
None
ID
string
Yes if this parameter is used as a request parameter and Type is set to a user
Explanation:
Account (domain) ID of the grantee.
Restrictions:
None
Value range:
To obtain an account ID, see Obtaining the Account ID.
Default value:
None
Name
string
No if used as a request parameter
Explanation:
Account name of the grantee.
Restrictions:
  • The account name starts with a letter.
  • The account name contains 6 to 32 characters.
  • The account name only allows letters, digits, hyphens (-), and underscores (_).
Value range:
None
Default value:
None
URI
GroupUriType
Yes if this parameter is used as a request parameter and Type is set to a group
Explanation:
Authorized user group
Restrictions:
None
Value range:
See Table 6.
Default value:
None
Table 5 GranteeType
Constant
Default Value
Description
GranteeGroup
Group
Grants permissions to user groups.
GranteeUser
CanonicalUser
Grants permissions to individual users.
Table 6 GroupUriType
Constant
Default Value
Description
GroupAllUsers
AllUsers
All users
GroupAuthenticatedUsers
AuthenticatedUsers
Authorized users. This constant is deprecated.
GroupLogDelivery
LogDelivery
Log delivery group. This constant is deprecated.
Table 7 PermissionType
Constant
Default Value
Description
ObsClient.enums.PermissionRead
READ
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
ObsClient.enums.PermissionWrite
WRITE
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not applicable to objects.
ObsClient.enums.PermissionReadAcp
READ_ACP
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
ObsClient.enums.PermissionWriteAcp
WRITE_ACP
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
ObsClient.enums.PermissionFullControl
FULL_CONTROL
A grantee with this permission for a bucket has PermissionRead, PermissionWrite, PermissionReadAcp, and PermissionWriteAcp permissions for the bucket.
A grantee with this permission for an object has PermissionRead, PermissionReadAcp, and PermissionWriteAcp permissions for the object.
Responses
Table 8 Responses
Type
Description
Table 9
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 9.
Table 9 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 10.
InterfaceResult
Table 11
Explanation:
Results outputted for a successful call. For details, see Table 11.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 10 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 11 BaseResponseOutput
Parameter
Type
Description
RequestId
string
Explanation:
Code Examples: Enabling Bucket Logging
This example configures logging for bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function setBucketLogging() {
    try {
        const params = {
            // Specify the bucket name.
            Bucket: "examplebucket",
            // Specify an agency name (obs_test_agency in this example).
            Agency: 'obs_test_agency',
            LoggingEnabled: {
                // Specify a bucket (TargetBucketname in this example) for storing generated log files.
                TargetBucket: 'TargetBucketname',
                // Specify a prefix (TargetPrefixtest/ in this example) for log files to be generated.
                TargetPrefix: 'TargetPrefixtest/',
                // Specify the grantee permissions.
                TargetGrants: [
                    // Grant the read permission to a specific user. In this example, the user ID is 0a03f5833900d3730f13c00f49d5exxx.
                    { Grantee: { Type: 'CanonicalUser', ID: '0a03f5833900d3730f13c00f49d5exxx' }, Permission: obsClient.enums.PermissionRead }
        // Configure logging for a bucket.
        const result = await obsClient.setBucketLogging(params);
        if (result.CommonMsg.Status <= 300) {
            console.log("Set bucket(%s)'s logging configuration successful!", params.Bucket);
            console.log("RequestId: %s", result.CommonMsg.RequestId);
            return;
        console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
        console.log("Status: %d", result.CommonMsg.Status);
        console.log("Code: %s", result.CommonMsg.Code);
        console.log("Message: %s", result.CommonMsg.Message);
    } catch (error) {
        console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
        console.log(error);
setBucketLogging();
Code Examples: Disabling Bucket Logging
This example disables logging for bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
  //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    try {
        const params = {
            // Clear the logging configuration.
            LoggingEnabled : {}
        // Delete the access logging configuration of the bucket.
            console.log("Delete bucket(%s)'s logging configuration successful!", params.Bucket);
            return;
    } catch (error) {
        console.log(error);
setBucketLogging();
