Deleting Objects
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Deleting a Single Object
You can call ObsClient.deleteObject to delete a single object. Sample code is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.deleteObject({ Bucket: 'bucketname', Key : 'objectname' }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
Deleting Objects in a Batch
You can call ObsClient.deleteObjects to delete objects in a batch.
A maximum of 1000 objects can be deleted each time. Two response modes are supported: verbose (detailed) and quiet (brief).
- In verbose mode (default mode), the returned response includes the deletion result of each requested object.
- In quiet mode, the returned response includes only results of objects failed to be deleted.
Sample code:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); obsClient.deleteObjects({ Bucket: 'bucketname', // Set the response mode to verbose. Quiet : false, Objects : [{Key:'objectname1'},{Key:'objectname2'}, {Key : 'objectname3'}] }, function (err, result) { if(err){ console.log('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); if(result.CommonMsg.Status < 300 && result.InterfaceResult){ // Obtain the successfully deleted objects. console.log('Deleteds:'); for(var i in result.InterfaceResult.Deleteds){ console.log('Deleted[' + i + ']:'); console.log('Key-->'+result.InterfaceResult.Deleteds[i]['Key']); console.log('VersionId-->' + result.InterfaceResult.Deleteds[i]['VersionId']); } // Obtain information about objects that were not deleted. console.log('Errors:'); for(var i in result.InterfaceResult.Errors){ console.log('Error[' + i + ']:'); console.log('Key-->' + result.InterfaceResult.Errors[i]['Key']); console.log('VersionId-->' + result.InterfaceResult.Errors[i]['VersionId']); } } } });
Use the Quiet parameter to specify the response mode and the Objects parameter to specify the to-be-deleted objects.
Feedback
Was this page helpful?
Chatbot
