Uploading an Object - Browser-Based (SDK for Node.js)
Function
Performing a browser-based upload is to upload objects to a specified bucket in HTML form. The maximum size of an object is 5 GB.
You can call ObsClient.createPostSignatureSync to generate request parameters for a browser-based upload. You can use Node.js code to simulate a browser-based upload. For details, see post-object-sample. You can also perform a browser-based upload with the following steps:
- Call ObsClient.createPostSignatureSync to generate request parameters for authentication.
- Prepare an HTML form page.
- Enter the request parameters in the HTML page.
- Select a local file and upload it in browser-based mode.
Method
ObsClient.createPostSignatureSync(params)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name. Restrictions:
Value range: The value can contain 3 to 63 characters. Default value: None |
Key |
string |
Yes |
Explanation: Object name An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
Expires |
Number |
No |
Explanation: Validity period of authentication for a browser-based upload Restrictions: None Value range: A positive integer, in seconds Default value: 300 |
FormParams |
Object |
No |
Explanation: Parameters used for browser-based uploads, excluding key, policy, and signature. Restrictions: None Value range:
Responses
Parameter |
Type |
Description |
OriginPolicy |
String |
Explanation: policy not encoded using Base64. This parameter can only be used for verification. |
Policy |
String |
Explanation: policy in the form. |
Signature |
String |
Explanation: signature in the form. |
Code Examples
The following sample code shows how to generate the parameters in a browser-based upload request.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 |
// Import the OBS library. // Use npm to install the client. const ObsClient = require("esdk-obs-nodejs"); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // security_token: process.env.SECURITY_TOKEN, // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server: "https://obs.ap-southeast-1.myhuaweicloud.com" }); function createSignedUrlSync() { const params = { // Specify the bucket name. Bucket: "examplebucket", // Specify an object (example/objectname in this example). Key: "example/objectname", // Specify the validity period of the signed URL, in seconds (3600 in this example). Expires: 3600, // Specify the headers that must be carried in the request. FormParams: { 'x-obs-acl': 'public-read', 'content-type': 'text/plain' } }; // Create a signed URL for uploading an object. const res = obsClient.createPostSignatureSync(params); console.log("OriginPolicy : %s", res.OriginPolicy); console.log("Policy: %s", res.Policy); console.log("Signature: %v", res.Signature); }; createSignedUrlSync() |
Code of an HTML form example is as follows:
<html> <head> <meta http-equiv="Content-Type" content="text/html; charset=UTF-8" /> </head> <body> <form action="http://bucketname.your-endpoint/" method="post" enctype="multipart/form-data"> Object key <!-- Object name --> <input type="text" name="key" value="objectname" /> <p> ACL <!-- Object ACL --> <input type="text" name="x-obs-acl" value="public-read" /> <p> Content-Type <!-- Object MIME type --> <input type="text" name="content-type" value="text/plain" /> <p> <!-- Base64 code of the policy --> <input type="hidden" name="policy" value="*** Provide your policy ***" /> <!-- AK --> <input type="hidden" name="AccessKeyId" value="*** Provide your access key ***"/> <!-- Signature information --> <input type="hidden" name="signature" value="*** Provide your signature ***"/> <input name="file" type="file" /> <input name="submit" value="Upload" type="submit" /> </form> </body> </html>
Feedback
Was this page helpful?
Chatbot
